Publications of Huu Phuoc Bui
Publications HAL de bui de la structure shacra;mimesis
2017
Conference papers
titre
Real-time Error Control for Surgical Simulation
auteur
Huu Phuoc Bui, Satyendra Tomar, Hadrien Courtecuisse, Stéphane Cotin, Stéphane Bordas
article
BIOMECHANICS AND COMPUTER ASSISTED SURGERY MEETS MEDICAL REALITY, Aug 2017, Lille, France. 2017, <http://595.euromech.org/>
resume
Real-time simulations are becoming increasingly common for various applications, from geometric design to medical simulation. Two of the main factors concurrently involved in defining the accuracy of surgical simulations are: the modeling error and the discretization error. Most work in the area has been looking at the above sources of error as a compounded, lumped, overall error. Little or no work has been done to discriminate between modeling error (e.g. needle-tissue interaction, choice of constitutive models) and discretization error (use of approximation methods like FEM). However, it is impossible to validate the complete surgical simulation approach and, more importantly, to understand the sources of error, without evaluating both the discretization error and the modeling error. Our objective is thus to devise a robust and fast approach to measure the discretization error via a posteriori error estimates, which are then used for local remeshing in surgical simulations. To ensure that the approach can be used in clinical practice, the method should be robust enough to deal, as realistically as possible, with the interaction of surgical tools with the organ, and fast enough for real-time simulations. The approach should also lead to an improved convergence so that an economical mesh is obtained at each time step. The final goal is to achieve optimal convergence and the most economical mesh, which will be studied in our future work.
Accès au texte intégral et bibtex
https://hal.archives-ouvertes.fr/hal-01571194/file/euromech595_2017_Bui_et_al.pdf BibTex
