Publications of Raffaella Trivisionne
Publications HAL de Trivisonne de la structure shacra;mimesis
2017
Conference papers
titre
Augmented 3D Catheter Navigation using Constrained Shape from Template
auteur
Raffaella Trivisonne, Erwan Kerrien, Stéphane Cotin
article
Hamlyn Symposium, Jun 2017, London, United Kingdom
resume
In order to overcome the lack of depth perception in fluoroscopic images of endovascolar procedures, we propose a method to retrieve the 3D catheter navigation only having 2D information from x-rays images. The method is based only on image features and real-time constraint-based mechanical simulation.
Accès au texte intégral et bibtex
https://hal.inria.fr/hal-01545693/file/HSMR17_paper_58.pdf BibTex
2016
Conference papers
titre
3D Physics-Based Registration of 2D Dynamic MRI Data
auteur
Raffaella Trivisonne, Igor Peterlik, Stéphane Cotin, Hadrien Courtecuisse
article
MMVR – Medicine Meets Virtual Reality, Apr 2016, Los Angeles, United States. 2016
resume
We present a method allowing for intra-operative targeting of a specific anatomical feature. The method is based on a registration of 3D pre-operative data to 2D intra-operative images. Such registration is performed using an elastic model reconstructed from the 3D images, in combination with sliding constraints imposed via Lagrange multipliers. We register the pre-operative data, where the feature is clearly detectable, to intra-operative dynamic images where such feature is no more visible. Despite the lack of visibility on the 2D MRI images, we are able both to determine the location of the target as well as follow its displacement due to respiratory motion.
https://hal.inria.fr/hal-01254388/file/Trivisonne_R.pdf BibTex
2014
Conference papers
titre
Atlas-based Transfer of Boundary Conditions for Biomechanical Simulation
auteur
Rosalie Plantefeve, Igor Peterlik, Hadrien Courtecuisse, Raffaella Trivisonne, Jean-Pierre Radoux, Stéphane Cotin
article
MICCAI – 17th International Conference on Medical Image Computing and Computer Assisted Intervention, Sep 2014, Boston, United States. 2014
resume
An environment composed of different types of living tissues (such as the abdominal cavity) reveals a high complexity of boundary conditions, which are the attachments (e.g. connective tissues, ligaments) connecting different anatomical structures. Together with the material properties, the boundary conditions have a significant influence on the mechanical response of the organs, however corresponding correct me- chanical modeling remains a challenging task, as the connective struc- tures are difficult to identify in certain standard imaging modalities. In this paper, we present a method for automatic modeling of boundary con- ditions in deformable anatomical structures, which is an important step in patient-specific biomechanical simulations. The method is based on a statistical atlas which gathers data defining the connective structures at- tached to the organ of interest. In order to transfer the information stored in the atlas to a specific patient, the atlas is registered to the patient data using a physics-based technique and the resulting boundary conditions are defined according to the mean position and variance available in the atlas. The method is evaluated using abdominal scans of ten patients. The results show that the atlas provides a sufficient information about the boundary conditions which can be reliably transferred to a specific patient. The boundary conditions obtained by the atlas-based transfer show a good match both with actual segmented boundary conditions and in terms of mechanical response of deformable organs.
https://hal.inria.fr/hal-01070339/file/paper_1071.pdf BibTex
titre
Constraint-Based Simulation for Non-Rigid Real-Time Registration
auteur
Hadrien Courtecuisse, Igor Peterlik, Raffaella Trivisonne, Christian Duriez, Stéphane Cotin
article
Medicine Meets Virtual Reality, Feb 2014, Manhattan Beach, California., United States. 2014
resume
In this paper we propose a method to address the problem of non-rigid registration in real-time. We use Lagrange multipliers and soft sliding constraints to combine data acquired from dynamic image sequence and a biomechanical model of the structure of interest. The biomechanical model plays a role of regulariza-tion to improve the robustness and the flexibility of the registration. We apply our method to a pre-operative 3D CT scan of a porcine liver that is registered to a sequence of 2D dynamic MRI slices during the respiratory motion. The finite element simulation provides a full 3D representation (including heterogeneities such as vessels, tumor,. . .) of the anatomical structure in real-time.
https://hal.inria.fr/hal-01160739/file/MMVR14.pdf BibTex
Patents
titre
Interface de commande à distance d’un dispositif de contrôle et d’affichage d’informations dans une salle d’opération chirurgicale
auteur
Stéphane Cotin, Géry Casiez, Myriam Lekkal, Raffaella Trivisonne
article
France, N° de brevet: 14 60867. 2014
Accès au bibtex
BibTex
