The caribou project is aimed at multiphysics computation. It brings a plugin that complements SOFA multiphysics framework. It also provides generic C++ utilities, and SOFA components such as solvers and forcefields. The project is composed of two modules:
- the Caribou library which brings multiple geometric, linear analysis and topological tools that are designed to be as independent as possible from external projects;
- the SOFA Caribou library that is built on top of the caribou library, but brings new components to the SOFA project as a plugin.
